12 years agoJTAG to send a syncronized pulse to a large chained set of dev kits?
Hi, I have a set of these ARRIA V starter cards http://www.altera.co.uk/products/devkits/altera/kit-arria-v-starter.html Without going into much detail regarding why this design choice, ...
12 years ago --- Quote Start --- Does your PCI express motherboard support JTAG, do you have software drivers to operate it? --- Quote End --- Good question. Nothing stated in the Motherboard manual. And software drivers is a different story. Will require developing if its possible.. This path seems to be too much of a bother. --- Quote Start --- In principle (by design of the JTAG protocol), it's possible to update data registers of multiple devices in a JTAG chain simultaneously. Practically, I doubt that it's supported by standard tools, e.g. Altera Quartus. --- Quote End --- I see. Thanks for the heads-up. --- Quote Start --- With reasonable effort, connecting a hardware wire between the boards that propagate the trigger seems preferable. What's an acceptable delay and skew for the trigger? --- Quote End --- Delay is no issue. Can be seconds even. Of the top of my head, skew between all fpgas when they trigger should be less than 5nS. Slightly off-topic. But would a broadcast packet via ethernet accomplish this? There are gigabit ethernet ports available on the dev kit.. Edit.. PCI Express also has multicast. I can't seem to find skews for them though.. Thanks ZubairLK
