GBovi's avatar
GBovi
6 years ago
JTAG To Avalon Master Bridge sld node index or name set
When I instantiate the JTAGToAvalonMasterBridge, I need to choose the jtag index of this master. Because if I add another bridge I don't want the index of the existing ones changes. Another solution is a way to univocally choose the name of the master I see in SystemConsole with get_service_paths. With a fixed name I can get the corresponding index, even if it's changed.
  • EricMunYew_C_Intel's avatar
    EricMunYew_C_Intel
    Hi, Giorgio
    The instance index numbers are assigned by Quartus automatically during enumeration. I think user cannot directly determine how the index numbers are assigned.
    Eric
  • GBovi's avatar
    GBovi
    Thank for your reply Eric. This is not my problem.
    I can explain it with your example.
    I call master_0, master_1 and so on, different variables associated with different masters of my project.
    Let's say master_0=JTAG2Avln and master_1=Nios
    If now i want to add another master (for example another NIOS) to my project, the order can be redefined and I cannot use the same tcl source
    Quartus has an automated system of index association to JTAG nodes.
    But I have solved using Design functions. Loading a Design I have always the same symbolic name linked to the JTAG master, whatever index calculated.
    It's a solution, even if not so flexible, and I'm still trying to solve on the FPGA side, locking JTAG SLD Index of each master.
    Thank you Eric
    EricMunYew_C_Intel
    Hi, Giorgio
    You can get the list of all master services using get_service_paths in your System Console, and then assign a variable name to the first index of the list and so on.
    set masters [get_service_paths master]
    set master [lindex $masters 0]
    open_service master $master
    close_service master $master
    Am I answering your question ?
    Eric
