GBovi
6 years agoJTAG To Avalon Master Bridge sld node index or name set
When I instantiate the JTAGToAvalonMasterBridge, I need to choose the jtag index of this master. Because if I add another bridge I don't want the index of the existing ones changes. Another solution ...
GBovi
6 years agoThank for your reply Eric. This is not my problem.
I can explain it with your example.
I call master_0, master_1 and so on, different variables associated with different masters of my project.
Let's say master_0=JTAG2Avln and master_1=Nios
If now i want to add another master (for example another NIOS) to my project, the order can be redefined and I cannot use the same tcl source
Quartus has an automated system of index association to JTAG nodes.
But I have solved using Design functions. Loading a Design I have always the same symbolic name linked to the JTAG master, whatever index calculated.
It's a solution, even if not so flexible, and I'm still trying to solve on the FPGA side, locking JTAG SLD Index of each master.
Thank you Eric
