8 years agoJTAG timing constraints
Hi, Over the years my company has made many Altera FPGA designs, and for a long time the way-of-work for JTAG constraints remained undefined and of little consequence. Then for a couple Arria ...
8 years agoHello Daniel,
Do you use original Altera USB Blaster? The best reliable source is TimeQuest Analyzer Cookbook that is written by Altera. In DE1-Soc I have found an example with these constraints:# for enhancing USB BlasterII to be reliable, 25MHz
create_clock -name {altera_reserved_tck} -period 40 {altera_reserved_tck}
set_input_delay -clock altera_reserved_tck -clock_fall 3
set_output_delay -clock altera_reserved_tck 3
So you are not alone with JTAG problems on unconstrained designs. Actual values of constraints depends on your hardware (jtag connector to FPGA routes). Best regards, Leonardo
