AZaba3
7 years agoJTAG programming & active serial doesn't work
I'm using Cyclone 4E (EP4CE115F29C8N). When trying to load the FPGA via JTAG USB Blaster (SOF), the download sometimes fails and sometimes completes successfully but the device does not work. When ...
Vicky1
7 years agoHi,
I believe that, you would have done it earlier but, just ensure it again,
Select appropriate device present on the board in project, ensure pin assignment with respect to used board then perform full compilation & try to program the board.
you can also check the simple D flip flop programming on same board using JTAG & active serial.
Vikas
