17 years ago
Jtag problem
Here we go again!
For a very simple project i used a MAX7032S.
Suggested pullup an pulldown are used at jtag pins, connections kept as short as possible and large ground path as well.
Only way to download POF file to my handwired prototype is to fit few picos capacitors
across Clk, TMS and ground.
I would not like to fit this capacitor on the final PCB!!
Any suggestions ????
Thanks in advance
Alf
P.S.
Using BYTEBLASTER II
    Did you try the JTAG Chain Debugger in Quartus Programmer to narrow down the error analysis?
    I checked it. But "JTAG configuration invalid" on instantce manager and "No device in selected" on JTAG Chain Configuration window are display.
    If click Auto detect in programmer, it's display "Unable to scan device chain. Can't scan JTAG chain". Did I incorrect setting in menu? But I think that the settings in menu are simple. Why...???? Help me!!!
    JTAG debugger works also with no device detected. But it most likely won't give additional information. It can be used however, for some JTAG hardware checks.
    Hi, FvM
    All of Vcc connecting JTAG pullup resistor and the device are 5V in my board.
    For pogramming the device, does Vcc connecting JTAG pullup resistor change to 12V?
    Vcc of the device is 5V.
    Thank you.
