JTAG pin sharing in MAX10
JTAGEN is a dual-purpose pin. This pin functions according to the setting of the JTAG pin sharing option bit. If the JTAG pin sharing is not enabled, the JTAGEN pin is a regular I/O pin and JTAG pins function as JTAG dedicated pins.
If the JTAG pin sharing is enabled and the JTAGEN pin is pulled low, JTAG pins function as dual-purpose pins. If the JTAG pin sharing is enabled and the JTAGEN pin is pulled high, JTAG pins function as JTAG dedicated pins
Hence, if the pin is dedicated pin, it can't be used using user I/O mode.
Aiman
- liron875 years ago
I'm using 10M08 Evaluation Kit with the following configurations:
- JTAG pin sharing is enabled
- JTAGEN pin is pulled high
- FPGA sample JTAG pins as inputs regardless to JTAGEN state and I can't access JTAG (can't access the device) .
It doesn't fit with the configuration user guide
The only solution for access the device is to erase CFM while nconfig low
Please advise
Liron
