18 years agoJTAG pin 6
I design a board with cyclone II. I employ JTAG for configuration, signaltap ... My question is : What does pin n°6 of jtag be connected to ? In Cyclone handbook, it is just a note that says --- Quote Start --- Pin 6 of the header is a VIO reference voltage for the MasterBlaster output driver. VIO should match the device’s VCCIO. Refer to the MasterBlaster Serial/USB Communications Cable Data Sheet for this value. In the ByteBlasterMV cable, this pin is a no connect. in the usb-blaster and byteblaster ii cable, this pin is connected to nce when it isused for as programming, otherwise it is a no connect. --- Quote End --- Should I leave this pin unconnected ? or connected to 3.3V from the board ? On NiosII EP2C35 dev kit, it is connected to vccio through 1kOhm resistor.
Replacing the JTAG drivers should be sufficient to repair the parts.
To resume,
On cyclone II, (http://www.altera.com/literature/hb/cyc2/cyc2_cii5v1_06.pdf figure 13-25) JTAG pin 1 connected to FPGA TCK with 1k pulled down.....JTAG pin 2 connected to GND JTAG pin 3 connected to FPGA TDO..................................jtag pin 4 directly connected to vccio. JTAG pin 5 connected to FPGA TMS with 1k Pulled UP.........jtag pin 6 no connect (for usb blaster and byteblaster ii). JTAG pin 7 No Connect....................................................JTAG pin 8 No Connect. JTAG pin 9 to FPGA TDI with 1k Pulled UP.........................JTAG pin 10 to GND. Is it right ? 250$ burnt for just one pin :eek: :d - Altera_Forum
--- Quote Start --- I have burnt 2 USB Blaster (same symptoms) with card in which JTAG pin 4 and 6are connected to VCC --- Quote End --- The pin 6 connection involves an additional risk when connecting or disconnecting the USB interface while the USB Blaster is powered by the target board, because the JTAG drivers apparently aren't hot-plug proof. I didn't consider this problem in my above statement. --- Quote Start --- JTAG 4 goes to VCCA or VccIO through 1 kOhm --- Quote End --- No it's usually connected without a series resistor. Because the pin supplies the JTAG drivers in the USB Blaster, a series resistor must be at least low resistance to allow USB Blaster operation. - Altera_Forum
I have burnt 2 USB Blaster (same symptoms) with card in which JTAG pin 4 and 6 are connected to VCC. I notice that those 2 USB Blaster were > 1 year old and many, many, many operations.
On Altera's kits, JTAG 6 goes to VCC through 1 kOhm JTAG 4 goes to VCCA or VccIO through 1 kOhm I will have a look on Altera literature to figure out. - Altera_Forum
OK, thanks
The no connect doesn't imply, that the pin is unconnected at the USB Blaster. Cause this AS programming pin has no separate OE, it is also driven in JTAG mode, but to a high level. Thus you shouldn't have problems when shorting it to pin 4 (VCC) at the board.
SO, no need to connect to Vccio (3.3V) also, Could it be connected to Vccio without damage ? I think yes (I have this on older boards) - Altera_Forum
The USB-Blaster user's guide indicates this is a "No Connect" when operating in JTAG mode.
http://www.altera.com/literature/ug/ug_usb_blstr.pdf Jake
