18 years agojtag interface from user aplication
Hi, I'm trying to access the jtag port inside the fpga with the alt_jtag_atlantic block (also used in the jtag_uart for the niosII processor). I need access to the jtag port from a custom...
14 years agoHi
I'm trying to use the jtagatlantic library, but I have a problem when I call the function jtagatlantic_open(). I want to build a program with Dev-C++ to send data to the Nios II processor in my FPGA board. If I load the Nios II system in the board and I run the software in the Nios II processor since the Nios II SBT for Eclipse, when I run my C++ program the function jtagAtlantic_open() don't open the link. The function jtagatlantic_get_error() returns the value -6 (Target or port in use, see other_info) and the parameter other_info contains "Nios2 on 127.0.0.1". In the other hand, If I load the Nios II system but I don´t run any software in the Nios II processor, then the function jtagatlantic_open() run well. So, I think the problem is that the jtag uart can't be used at the same time by jtag atlantic and the Nios II program. What can I do about it? Thanks, David
