18 years agojtag interface from user aplication
Hi, I'm trying to access the jtag port inside the fpga with the alt_jtag_atlantic block (also used in the jtag_uart for the niosII processor). I need access to the jtag port from a custom...
17 years agoFvM,
Unfortunately, I am operating in the MSVC world. There is no such utility as IMPDEF.exe. However, using your method a did a bit of research and came up with a method to create the import library successfully. I tested it and it works correctly. I will attach my instructions to this post for others. Guten Tag und Danke, RNM
