15 years ago
JTAG did not work.
Hello all. We are make PCIe board at Aria GX2. It's highly simplified kit from Altera. The DC/DC is working very good. But JTAGs didn't work at all.
I can see signals at JTAG TDI, TMS, TCK but nothing at TDO. I'm try to connect TDI to MAX-II and ArriaGX-II in parallel and disconnect MAX TDO from Arria TDI. But I can't see signals at MAX TDO and Attia TDO.
I'm use 2.5v to supply MAX and Arria JTAG banks.
MSELs connected to ground. nConfig and nStatus I'm pull up.
    --- Quote Start ---
    According to the device manual, POR is monitoring these supply voltages:
    VCCCB, VCCA_PLL, VCC, VCCPD, and VCCIO for I/O banks 3C or 8C
    --- Quote End ---
    All voltages, pll, etc, is ok.
    --- Quote Start ---
    The JTAG tap controller enables TDO, when it's state advances to a SHIFT_DR or SHIFT_IR state. Never reaching this state (respectively not seeing TDO activated) in standard JTAG scan and similar actions most likely indicates:
    - device is held in reset, because one of the supply voltages required for JTAG operation (see the manual for details)
    --- Quote End ---
    Volatges is ok. Core - ok and IO Bank is ok.
    --- Quote Start ---
    is below it's reset threshold
    - TMS, TCK or TDO are not connected correctly
    --- Quote End ---
    I'm check this many times. It's ok. I'm even solder wire direct from JTAG pin to closed via from Arria chip.
    - device is held in reset, because one of the supply voltages required for JTAG operation (see the manual for details) is below it's reset threshold
    --- Quote Start ---
    This is a test.
    --- Quote End ---
    You test is ok. Jtag is't ok.
