Chen_feng7
4 years agoJTAG chain broken
I made a development board using MAX 10 series chips, and used TDI, TDO, TMS, TCK, and 4 JTAG pins to download the program.
In the windows environment, jtagconfig can obtain the device normally, bu...
- 4 years ago
Could you try to only connect to the 10M08 device? Are you using the onboard blaster or external blaster? If you are using onboard blaster then could you try to change the TCK frequency to 6Mhz?
JohnT_Altera
4 years agoHi,
Chen_feng7
4 years agoAnd I want to know why 24Mhz OSC can`t work, thanks.
