Chen_feng7
4 years agoJTAG chain broken
I made a development board using MAX 10 series chips, and used TDI, TDO, TMS, TCK, and 4 JTAG pins to download the program.
In the windows environment, jtagconfig can obtain the device normally, bu...
- 4 years ago
Could you try to only connect to the 10M08 device? Are you using the onboard blaster or external blaster? If you are using onboard blaster then could you try to change the TCK frequency to 6Mhz?
JohnT_Altera
4 years agoHi,
- Chen_feng74 years ago
And I want to know why 24Mhz OSC can`t work, thanks.
I I used onboard blaster and it`s frequency is 24Mhz.
I change the internal osc and I can read the second line when I run jtagconfig.
Thanks for your help!
