15 years agojtag_atlantic.dll missing
Hi all,
I am using Quartus and Nios EDS 10sp1 on winddows 7 64bit. I cannot run nios2-terminal command, it gives an error like this: "The program can't start because jtag_atlantic.dll is missing from your computer. Try reinstall the program to fix this problem." After trying to copy the jtag_atlantic.dll in folder \altera\10.0sp1\quartus\bin64 and E:\altera\10.0sp1\quartus\bin to windows\system32. It gives another error like this: "The application was unable to start correctly (0x000007b). Click OK to close the application" can anyone help me to fix it? PS. Today I use modelsim to simulate NIOS II, and I issue a command jtag_uart_drive to display an interactive console. The result is no window appear and i discover the problem, I cannot launch the nios-terminal! Thank in advance.1 Reply
The problem is solved! After insert \altera\10.0sp1\quartus\bin and \altera\10.0sp1\quartus\bin\cygwin\bin into PATH environment variable. It works perfectly.
