15 years agoJTAG and/or IO pin usage
Hello all, I'm new to CPLDs but I'm very keen on getting a little project up and running soon. The basic question is: is it possible to program a EPM3064 through the JTAG pins, then use th...
15 years ago --- Quote Start --- I'll just treat the JTAG port as if it's always a JTAG port then --- Quote End --- That is generally the best way to do things. --- Quote Start --- I want to get rid of the header & connect some uC IO to the CPLD with the same uC IO doing JTAG-y stuff as well as mode selection for my user code. --- Quote End --- In that case, check out the JTAG-y stuff in this schematic: http://www.ovro.caltech.edu/~dwh/carma_board/gda06rb004_carma_v0.87_dec03.pdf (http://www.ovro.caltech.edu/%7edwh/carma_board/gda06rb004_carma_v0.87_dec03.pdf) Why are you thinking of using this particular CPLD? The MAX II devices are much nicer, eg., EPM570 in a TQFP 100 package. When I want a little glue logic, I find that one quite handy. The schematic I just referenced to uses a couple of them. Cheers, Dave
