16 years agoJTAG & AS configuration
Hello community, I've a basic problem (I think for you...) in programming a serial configuration device (EPCS16 & EP2C50) using JTAG interface. I'm using the following scheme : combining JTA...
16 years agoHi,
I had a similar problem when I constructed a chain with four Phys. The solution was to get the *.bsdl File for the Phy. You should see the unknown devices in the chain I think. If you klick with the right button on one of them choose change device. In the popup-box you can import the *.bsdl files from Xilinx. I hope this helps you out.
