16 years agoJTAG & AS configuration
Hello community, I've a basic problem (I think for you...) in programming a serial configuration device (EPCS16 & EP2C50) using JTAG interface. I'm using the following scheme : combining JTA...
16 years agoHi FvM,
Thank you for your answer. --- Quote Start --- Did you already try other virtual JTAG instances --- Quote End --- No, I'm ALTERA beginner and I don't know these functions ! If you know quick test that I can do, let me know. --- Quote Start --- JTAG variants don't due to signal quality problems of the JTAG chain (ringing TCK) --- Quote End --- I just check the JTAG signals integrity with scope, TCK is clean and is in phase with data. It seems that ALTERA programmer successfully configure my EP2C50 but got error when trying to program the flash memory device (EPCS16).
