17 years agoJitters at counter output
Dear all, I encountered strange jitter problems in my behavioral simulation. I use register as a counter, then output the counter value, the simulations shows no jitter at register signa...
17 years agoCompletely normal. Even if you didn't see this in the simulation, you would in the device. And note that the device will have more variance than that simulation, which is probably only showing worst case delays. Every delay has a range over Process, Voltage and Temperature. The downstream device is what OE is sending it's data too.
