AGofs
7 years agoI've upgraded Quartus ii,from Rev.10.1 to Rev.13.1. After upgrade the "Available Devices list" is an inactive. How can I make it active?
I've upgraded Quartus ii,from Rev.10.1 to Rev.13.1 . I'm opening new project with "New Project Wizard". At some stage I want to select specific device from "Select from Available devices list" opti...
Vicky1
7 years agoHi Alex,
It may happen due to setup a global environment variable 'QUARTUS_ROOTDIR_OVERRIDE' that pointed to a different version of Quartus installed on the machine.
Generally every time quartus launches, it will override the 'QUARTUS_ROOTDIR' environment, but not the 'QUARTUS_ROOTDIR_OVERRIDE' one, which need to be manually changed if a different version of quartus is used.
Go to "System"->"Advanced System settings"->"Environment variable"..
check the "QUARTUS_ROOTDIR" pointing to the Quartus13.1.
Vikas
- AGofs7 years ago
Hi Vikas, It doesn't point to the Quartus13.1. I've changed to the Quartus rev. 13.1 , But the "Available Devices list" still inactive and I cannot select specific device.
