Issue with Seven Segment
- 2 years ago
If the inputs are unconnected and there's no pull-down resistors or other physical means to pull them down to the a low state, then you have no reason to expect that they would default to a low state. The state of a floating input should be regarded as unpredictable. In fact, with some devices, floating inputs can float to the transition region and/or oscillate, which can cause all kinds of problems including excessive power consumption and noise. Letting inputs float without some physical means to pull them definitively in one direction or the other is generally bad practice that should be avoided.
Fortunately for you, the FPGA's I/O cells have a build-in means to do this, including internal weak pull-ups that can be optionally enabled. The fact that your inputs seem to be defaulting to the high state when unconnected suggests that you might already be enabling these pull-ups, whether you knew it or not.
If I may make a suggestion about how to handle this in your design, you should make sure to enable these pull-ups, first and foremost. But then, also, you can actually take advantage of the fact that they pull your input vector to this numerically invalid state of all high. You can have your logic detect this as a way to determine that your inputs are unconnected, in which case you could put up an appropriate indication on the 7-seg displays, like "----" or "Err" or some such thing.
I see that community users have helped you in your case.
On your query related to undriven input pins, the pins can be read as high or low. It is unpredictable. Occasionally it could be read as high due to some leakage current following through the pins.
Hope this answers your question.
