17 years agoISP1362 usb device
hello i'm trying to get the USB on my DE2-70 board to work as a device. And the host is the PC. I do not want to use the NIOS processor... I followed the step by step register initialisation ...
17 years agohello
I am now working in a project which needs to make the DE2-70 board as a USB device and the host is the PC. I write some codes in vhdl to communicate with the ISP1362, because I can not to use the NIOS processor... When I try to probe the system, I found these problems: 1) If I connect both the blaster cable and the device cable to the pc or only the blaster, the host shows initially the blaster, then I download the firmware to the FPGA and the system do the Enumeration and initialization process and the ISP1362 is recognize by the host PC. But, if I disconnect the blaster cable, the system is not respond, then I reset the driver by the firmware and the device is doesn't show by the host. I am using the VISA USB Raw of National Instrument and its driver in the host. 2) If I work with both the blaster cable and the device cable connected, the system can transmit data from PC to device successful, but when I try to send data from device to host PC, it show me a timeout error. I check the firmware step by step and it apparently work correctly.
