17 years agoISP1362 usb device
hello i'm trying to get the USB on my DE2-70 board to work as a device. And the host is the PC. I do not want to use the NIOS processor... I followed the step by step register initialisation ...
17 years agohi,
well due to the fact that i'm on a tight schedule, i had to let it go for now... I got really upset with it and deleted the sources...so I can't help you with what I've done... I will get back to it in about 2 months...if you can wait that long:) After giving up on this I also played a bit with the NIOS processor...It has some kind of interface with the ISP1362...I didn't actually use this neither, but from what I understand, it should be a lot easier than writing your own module...now it depends on what you're aiming at. If you need any help with this part, i'll do what I can :) ps: I'm from Romania
