11 years agoIs there an IP I can use to do Bit Error Ratio Tester for Gigbit transceivers?
I have a design which will use gigbit transceivers, I wonder is ther an IP I can use to do Bit Error Ratio Tester to verify whether the hardware is in good shape or not? Thanks in advance.
11 years ago --- Quote Start --- It seems the PRBS pattern generator and checker, these two IPs are not in Quartus II as default, we have to download them and install, right? --- Quote End --- They are standard components. Open Qsys, type "Pattern" in the IP Catalog search box, and you'll see the Avalon-ST pattern generator/checker components. There are several components. Read the documentation for each to determine which ones you want. Better yet, just open the examples at the link I provided above and see what they used (once the Altera site comes back online). Cheers, Dave
