11 years agoIs there an IP I can use to do Bit Error Ratio Tester for Gigbit transceivers?
I have a design which will use gigbit transceivers, I wonder is ther an IP I can use to do Bit Error Ratio Tester to verify whether the hardware is in good shape or not? Thanks in advance.
11 years ago --- Quote Start --- Use the Transceiver Toolkit ... its part of the Quartus GUI http://www.altera.com/products/software/quartus-ii/transceiver/swf-transceiver-toolkit.html http://www.altera.com/support/examples/on-chip-debugging/on-chip-debugging.html Basically the examples create a Qsys system with a PHY, a PRBS pattern generator and a checker. You can then the Quartus Transceiver Toolkit GUI to control the Qsys system and generate bath-tub plots, etc. Cheers, Dave --- Quote End --- Thanks very much, Dave. Now Altera website is in maintenance which I can't check them now. It seems the PRBS pattern generator and checker, these two IPs are not in Quartus II as default, we have to download them and install, right? Thanks.
