11 years agoIs there an IP I can use to do Bit Error Ratio Tester for Gigbit transceivers?
I have a design which will use gigbit transceivers, I wonder is ther an IP I can use to do Bit Error Ratio Tester to verify whether the hardware is in good shape or not? Thanks in advance.
11 years agoUse the Transceiver Toolkit ... its part of the Quartus GUI
http://www.altera.com/products/software/quartus-ii/transceiver/swf-transceiver-toolkit.html http://www.altera.com/support/examples/on-chip-debugging/on-chip-debugging.html Basically the examples create a Qsys system with a PHY, a PRBS pattern generator and a checker. You can then the Quartus Transceiver Toolkit GUI to control the Qsys system and generate bath-tub plots, etc. Cheers, Dave
