19 years agoIs "Output, Driving Ground" same as out_pin <='0';
I have a design which uses the unused pins are set to "Output, Driving Ground" setting. I thought I would prefer to explicitly set them to ground in the VHDL. I did this and did a compare of the...
19 years agoThanks I think I understand now.
I just started using Quartus in July ... my previous Altera design was a 10K10 in MaxPlusII! This new software is VERY sophisticated, and it looks like you need to leave the gui behind to realize it's true power. I had used the gui to do this: set_global_assignment -name RESERVE_ALL_UNUSED_PINS "AS INPUT TRI-STATED WITH WEAK PULL-UP" But never even realized this was possible: set_location_assignment PIN_E2 -to unused_pin set_instance_assignment -name RESERVE_PIN "AS OUTPUT DRIVING GROUND" -to unused_pin Is there a good reference for the qsf file contents? So far I've been learning by observing what the gui does in there. BTW: Are you an Altera employee, or just trying to become one:) Thanks again Steve
