19 years agoIs "Output, Driving Ground" same as out_pin <='0';
I have a design which uses the unused pins are set to "Output, Driving Ground" setting. I thought I would prefer to explicitly set them to ground in the VHDL. I did this and did a compare of the...
19 years agoIf you reserve an unused pin as "As output driving ground", the .pin file and Fitter report "All Package Pins" table will list that pin as "GND*". The top of the .pin file says the GND* pins may be connected to ground on the board or left unconnected.
I don't know of another place where you can see that the pin is programmed as a hard zero. When I tried the Chip Planner for that so that I could locate from there to the Resource Property Editor, I wasn't able to do it for an unused pin.
