16 years agoIs it possible to use GX Transceiver for OC3 application i.e 155.52 Mbps
Hi. Is it possible to use GX transceiver in Arria II at dat rate of 155.52 Mbps for SONET OC3 application. when I reffered the device datasheet, it indicates the minimum data rate as 600 Mbps. Bu...
15 years agoIt seems that Arria II GX doesn't support OC-3. Maybe there is a error in the datasheet.
