15 years agoIs it possible to handle two IP addresses with one Ethernet device?
Hi all, I'm new about TSE and Nichestack and NIOS II, therefore keep it in account within eventual your answer to my post... :) I would like to know if is possible to handle two IP addresses ...
15 years agoThank you Daixiwen,
I don't think that Multicast is the right solution for me because my customer wants to have the possibility to connect to my device using two different IP (one fixed and one dependent on one device parameter). Now I will try to understand effort required to modify Nichestack (I have to use that TCPIP stack or as alternative Micrium one) and eventually handle only one IP address at runtime and give to my customer a simple way to switch to other IP address. Ciao
