10 years agoIs it possible to connect any FPGA board to a dimm slot directly?
Hi, We are looking for a FPGA solution which can be used for replacing the DRAM and connect a FPGA board to a dimm slot directly. The DRAM should be on the FPGA board. What we want to do i...
10 years agoThe FPGA should locate between the slot and the memory to intercept and encrypt/decrypt the data.
DDR3 is preferred, and DDR2/4 should also work. About the speed, as far as it can support OS booting and running, it should be fine for now! Thanks!ohault
4 years agoHello,
With technological advancements of FPGA and the availability SDRAM Controller IPs, I guess the answer to this question should be revisited.
Kind regards,
Olivier
