10 years agoIs it possible to connect any FPGA board to a dimm slot directly?
Hi, We are looking for a FPGA solution which can be used for replacing the DRAM and connect a FPGA board to a dimm slot directly. The DRAM should be on the FPGA board. What we want to do i...
10 years agoSo you mean that if a FPGA locates between the system memory controller and the memory, the performance will be too bad to run any OS on it? I'm new to this area, please let me know if my proposed solution doesn't make sense. Thanks.
