11 years agoIris recognition on FPGA
Dear All, Good day. I want to implement iris circle detection algorithm. Once the iris circle is detected, the detected image will be compressed using jpeg2000 and sent to host using USB i...
11 years agoDear All,
thanks for reply.ing so far..but Altera devices has made me more confused..now which device to use for my project. 1>Only FPGA? 2>Only NIOS processor? 3>SOC FPGA+Processor? 4>DSP builder using simulink? please consider below requirement for answerring above question. Define your requirements in terms of things like: •image size - 640 x 480 •frame rate - 30 fps •bit depth - 8 bit gray scale (need to convert raw rgb to grey scale) •acceptable latency - real time •processing required - mainly segmentation for iris circle detection and then jpeg200 compression, and cryptography for security purpose •unit cost - as low as possible but not more than 50$ •power consumption target - should be power on ethernet/usb Br, Abdul •how long you have to get this to market - 1 year
