11 years agoIris recognition on FPGA
Dear All, Good day. I want to implement iris circle detection algorithm. Once the iris circle is detected, the detected image will be compressed using jpeg2000 and sent to host using USB i...
11 years agoThe DE1 is a smaller board based on an older smaller cyclone II part. These can't run as fast as newer technology, and don't have as many resources as newer chips. Make sure you check your memory and resource requirements against what's available on that board. Your block diagram doesn't include enough details to tell if it will work on the DE1. In any case, it's up to you to decide to get a bigger board or design your project to fit what's available on the DE1.
