15 years agoIQ down converting speed
I need some advice on device speeds. I want to implement a simple IQ down converter. A simple test taking an input signal from an A/D (6 clocks to read), & mixing it with an NCO, implemented in a...
15 years agoLooks to me that konrad is using a 50 MHz ADC (with 300 MHz DDR serial interface), so the base frequency requirement is only 50 MHz which should be easy for Cyclone III.
