19 years agoIP protection attribute
Hi, Does altera have an attribute thay you can set in your vhdl code that will stop someone viewing the RTL and Technology views. I know Xilinx has a few attribute that can be set, that hides a...
19 years agoI believe the .vqm writer is being discontinued for newer families, so that won't be an option going forward. It's also pretty susceptible to reverse-engineering since it's a structural verilog(you could argue everything is, depending how much time they want to put into it).
Another option is to export your design as a partition. The user could just import that into their design. It's a little more "strict" on how it needs to be hooked up since it won't go through synthesis again, but the .qxp file is a binary that stores information in the langauge of Quartus's database, not a known format like verilog. They both have their pros and cons.
