19 years agoIP protection attribute
Hi, Does altera have an attribute thay you can set in your vhdl code that will stop someone viewing the RTL and Technology views. I know Xilinx has a few attribute that can be set, that hides a...
19 years agoIt won't help at the technology map level, but you can at least protect your IP at the RTL level by providing a .vqm file instead of a VHDL file. Run Analysis & Synthesis. Then run "Processing --> Start --> Start VQM Writer".
