14 years agoI/O states in Cyclone III in JTAG mode
Hello all, In Altera's application notes it is specified that during JTAG mode all I/O pins are tristated. It is sometimes mentioned that the weak pull ups are enabled when the I/O pins are t...
14 years agoAltera preferred to omit the clearer description in previous device handbook versions.
Now the information is hidden in Note (1) to table 12-3: --- Quote Start --- Bus hold and weak pull-up resistor features override the high-impedance state of HIGHZ, CLAMP, and EXTEST. --- Quote End --- In previous versions, there was an explicite explanation of individual BST instructions affecting the IO states, e.g. for CLAMP: --- Quote Start --- If you are testing after configuring the device, the programmable weak pull-up resistor or the bus hold feature overrides the CLAMP value (the value stored in the update register of the boundary-scan cell) at the pin. --- Quote End --- In any case, if you are in doubt about the real device behaviour, why don't you simply try it?
