I/O Standard
Hello Divakar,
I see you are using Cyclone IV on your design. Are you referring to Vccio? If yes, the range of Vccio in 3.0-V LVCMOS is from 2.85V to 3.15V. Supplying Vccio of 3.3V on this bank is not recommended since it is above the range and I cannot validate whether it will be safe or not to your device. I would recommend you to follow I/O Standard Specs from Cyclone IV Device Datasheet Table 1-15 page 12: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-iv/cyiv-53001.pdf .
Thank you.
Can it damage the device? I see the absolute maximum rating is 3.45.
- AminT_Intel5 years ago
Hello RDiva,
Unfortunately no. The current strength from the table I shared with you is only from -2mA to 2mA for 3.3V LVCMOS. I am sorry I cannot validate if it will be safe for your device if you set specifications beyond our range from that document. Do you need any more clarification?
Thank you.
Hello RDiva,
I hope your problems have been solved. I will close this case in 3 days if there is no further questions from you.
Thank you.
- RDiva5 years ago
What is the absolute maximum? Is it still, 3.75 per table 1-1?
