ShivaKi's avatar
ShivaKi
2 years ago
I/O pins not used
For Cyclone V part 5CEBA7F27C8N, the I/O pins which are not used should be left floating or connected to Ground?
Referred to Pin connection guidelines document, related data for I/O pins is not present
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    AqidAyman_Altera
    I would like to follow up on you for this issue.
    Do you need more clarification on this? Or I can close this thread?
    AqidAyman_Altera
    It is recommended connecting I/O pin that was not used as what defined in the Quartus Prime software
