15 years ago
I/O Pin voltage
I am trying to design a simple multiplexer using the Cyclone III FPGA on the DE0 board. I am using the PLL to divide the 50MHz on board clock down to the appropriate speed. However whenever I try to put a signal out to one of the I/O pins, it is only about 20mV peak to peak. I understand the pins on the DE0 board should put out 3.3V. I have the pins assigned to the 3.3V standard in the Quartus II pin planner, but it doesn't seem to make any difference. Any help would be appreciated.
1 Reply
    You can try the following steps to set the output voltage:
    Menu : Assignments -> Device -> Device and Pin Options
    In Voltage Tab you can choose 3.3V LVTTL for Default I/O Standard.
    Then don't forget compile your project.
    I also use DE0 board and every time I use the default voltage.
    I hope it can help you.
