I/O D1/D3 delay values higher than needed.
Hi Anand.
Finally me and my colleague "successfully" recreated the issue in a simple test project.
The project on its top-level consists of three parts - CLOCK, ETHERNET and a simple DAC part.
CLOCK consists of two PLLs, first PLL is for all clocks used in project, and second is for RX part of ETHERNET only, it receives rx_clock from TSE rx and in Source Synchronous Mode outputs clock for latching the RX data to the appropriate I/Os.
ETHERNET consists of triple speed ethernet core and DDIO for TX clock output.
DAC consists of a very simple bunch of code, and the most interesting thing is that it is clocked by 200 MHz clock by default.
So the issue which I mentioned in the beginning of that post was recreated.
We also found what action should be done for the issue to disappear - we changed the source clock for DAC part from 200 to 100 MHz and the result is on the picture below:
So the interesting part of an issue is that there is another block whose source clock comes from another PLL has an impact on timing (in particular the I/O internal delay values). As I previously mentioned we can correct I/O internal delay values manually and obtain the correct timing.
I attached the project.
Ivan
