15 years agoI/O Buffers
Is it necessary to use i/o buffers while writing code for altera in VHDL. Can i write the code without buffers,if no can anyone please explain why? Thanks in advance3 Replies
Usage of low level primitives in functional VHDL simulation seems meaningless at first sight. What you are trying to achieve this way?
Did you experience any benefit from using low level primitives? - Altera_Forum
Actually i am using GHDL as my simulation tool and for maximum optimization i am writing using very low level primitives.So in that case do i need to instantiate i/o buffers? Thanks in advance. - Altera_Forum
in general you don't need to instantiate buffers in HDL, you use the Pin Planner/Assignment Editor to make I/O related assignments
you may also use the MegaWizard for PLLs, LVDS/SERDES, gigabit SERDES, which would then be instantiated in your HDL
