15 years agoInvalid MAC Address stored at Flash Offset 0x8000
the hardware and software i use are based on“niosii_ethernet_standard_3c25.zip” and“nichestack_tutorial” from altera pages.
after running , In NiosII IDE software, console is below: PHY INFO: [phyid] 0x1 2000 5c90 PHY INFO: Issuing PHY Reset PHY INFO: waiting on PHY link... PHY INFO: PHY link detected, allowing network to start. SSS INFO: Connecting... =============== Software License Reminder ================ This software project uses an unlicensed version of the NicheStack TCP/IP Network Stack - Nios II Edition. If you want to ship resulting object code in your product, you must purchase a license for this software from Altera. For information go to: "http://www.altera.com/nichestack (http://www.altera.com/nichestack)" ================================================== === InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 EEPROM device 24LC0 size is 10 read[0x000]: control byte 1 was not ACKed Signature = 0x0. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!! Your NEEK LCD daughtercard is not programmed with a correct MAC Address! Please contact Altera support for instructions on how to correct this problem! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!! Invalid MAC Address stored at Flash Offset 0x8000 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!! Unable to find Valid MAC address. Please refer to your Board's User Guide for instructions on restoring the MAC Address for your board. --Or-- Hard Code MAC address in get_mac_addr() of iniche_init.c !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!! prepped 1 interface, initializing... [tse_mac_init] INFO : TSE MAC 0 found at address 0x07002800 INFO : PHY National DP83848C found at PHY address 0x01 of MAC Group[0] INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED INFO : PHY[0.0] - Checking link... INFO : PHY[0.0] - Link established INFO : PHY[0.0] - Speed = 100, Duplex = Full OK, x=0, CMD_CONFIG=0x00000000 MAC post-initialization: CMD_CONFIG=0x04000203 [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created mctest init called IP address of et1 : 0.0.0.0 Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) DHCP timed out, going back to default IP address(es) Nios II Simple Socket Server starting up. Created "monitor_phy" task (Prio: 9) Created "Nios II Simple Socket Server" task (Prio: 10) [SSS_task] Nios II Simple Socket Server listening on port 30 The wrong places are in red my quastions : 1:my quartusII version is 9.0,but pdf says 9.1 sp or later,does it matter? 2: in NIOSII IDE,according to the example,I set DHCP on,it means that ip and gateway all should be set to 0 ? how to set these values manually? 3: by the function "get_mac_addr()",does the system set NEEK mac address automatically and place it in flash?why the error"Invalid MAC Address stored at Flash Offset 0x8000"and "Unable to find Valid MAC address"generate? I am sorry that my English is not very good, I am appreciate that somebody could help me!!! thanks __________________1 Reply
- License reminder
This is because you are using the unlicensed Interniche Stack. You can fully use it for evaluation purposes but you need to buy the licence if you decide to develop a product with it. - DHCP warning This is not an issue. You probably are connected directly to your pc, which has not a DHCP server active. Since nobody assigns a ip address to the boards, it switches to the default ip address after a timeout. - other warnings I don't have another dev board, so I don't know the correct procedure for programming ip and eth addresses in your case. Refer to the kit manual. Usually those address are blank when the board is delivered and then it asks you to enter valid addresses the very first time you start the application, isn't it? Maybe you failed to enter the addresses, i.e. typing all zeros. Again in the manual, you'll certainly find the procedure to reset the board to factory settings. Regards
