8 years agoinvalid data received when communicating over ULPI bus
I have implemented simple FPGA-design that tries to read vid/pid register from ULPI PHY presented on DECA board over ULPI bus. But unfortunately my project is not working correctly. I am able t...
8 years agoHi,
--- Quote Start --- // High level of dir means that PHY transmitting, otherwise it is waiting for data from us. assign ulpi_in_w = usb_ulpi_dir ? usb_ulpi_data : 8'b0; assign usb_ulpi_data = usb_ulpi_dir ? 8'bZ : ulpi_out_w; --- Quote End --- Here “ulpi_in_w” will have either 8’bZ or 8’b0 and that will update the “ulpi_value” which decides VID_HIGH, PID_HIGH and PID_LOW, VID_LOW as in the following instantiation, .ulpi_in(ulpi_in_w),--- > ulpi_value <= ulpi_in; ----> .ulpi_value(ulpi_value), ---> ulpi_valuecase (ulpi_reg)
REG_VID_LOW:
begin
vid <= ulpi_value;
ulpi_reg <= REG_VID_HIGH;
end
REG_VID_HIGH:
begin
vid <= (ulpi_value << 8) | vid;
ulpi_reg <= REG_PID_LOW;
end
REG_PID_LOW:
begin
pid <= ulpi_value;
ulpi_reg <= REG_PID_HIGH;
end
REG_PID_HIGH:
begin
pid <= (ulpi_value << 8) | pid;
request <= 0;
state <= IDLE;
end
endcase --- Quote Start --- Another anomaly that I noticed is that usb_ulpi_nxt is set on the same tick as I put usb_ulpi_data. As far as I understand from ulpi_doc_timing.png usb_ulpi_nxt bit should be set on the second tick after start of usb_ulpi_data transmission from us. This is very strange for me that usb_ulpi_nxt is set on the same tick as data started to be streamed from usb_ulpi_data. --- Quote End --- Check design code again. Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation)
