8 years agointerfacing to epcq256 through fpga
Hello, I've posted this before but I'm trying to interfacing to the epcq256 via the fpga in order to store a counter on the epcq. I'm using the ASMI parallel core in order to transfer data to a...
8 years agoHi AMalexander,
Check the busy signal before sending a new command. When the busy signal is deasserted, allow two clock cycles before sending a new signal. This delay allows the circuit to reset itself(IP) before executing the next command For more information click here (https://www.altera.co.jp/ja_jp/pdfs/literature/ug/ug_altasmi_parallel.pdf) Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
