8 years agointerfacing to epcq from fpga?
Hello all, I've been assigned a task at work that requires me to access the epcq from the fpga in order to store data on it. However, the epcq is used for storing the configuration file for the...
8 years agoHi Alexander, Yes we can establish the communication with the flash(there are different methods). Have loaded .sof file is it working fine? If Yes, Generate .jic and load the flash with .jic. 1.Are you using development board/ custom board?Can you share the information of Kit part number/ part number of flash? Converting .sof to .jic Files in the Quartus II Software To convert a .sof to a .jic file, perform the following steps: 1. On the File menu, select Convert Programming Files. 2. In the Convert Programming Files dialog box, select JTAG Indirect Configuration File (.jic) from the Programming file type drop down menu. 3. In the Configuration device field, specify the targeted serial configuration device. 4. In the File name field, browse to the target directory and specify an output file name. 5. Highlight the SOF Data in the Input files to convert window. 6. Click Add File. 7. Select the .sof file that you want to convert to a .jic file. 8. Click OK. 9. Highlight Flash Loader and click Add Device. 10.In the Select Devices dialog box, select the targeted FPGA that you are using to program the serial configuration device. 11.Click OK. 12.Click Generate. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
