8 years agointerfacing to epcq from fpga?
Hello all, I've been assigned a task at work that requires me to access the epcq from the fpga in order to store data on it. However, the epcq is used for storing the configuration file for the...
8 years agoHi Alexander,
There is an IP core (Altera ASMI Parallel IP Core) that can give you access to the configuration flash. See this user guide: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_altasmi_parallel.pdf Regards, Mathias
