8 years agoInterfacing of Cyclone V GX starter kit with AFE5809EVM
I'm new to Altera devices and i am working on a project to interface AFE5809EVM with cyclone V GX starter kit using the HSMC-ADC-Bridge connector. Does anyone has any knowledge about how to do it. Pl...
8 years agoHi,
If you're chip uses LVDS signalling, you can interface it to FPGA via the HSMC bridge. Make sure the input pins for these signals are set as LVDS in the pin planner. This way you will be able to read in the LVDS data from the chip into the FPGA. The LVDS IO at the FPGA will convert the differential signals to single-ended ones internally at the IOBUF level. Thus you will get single-ended signals from the LVDS IO inside the FPGA and you can use it for other logical purposes in the core logic. Does this answer your question?
