8 years agoInterfacing FPGA pins to an external bidirectional bus.
OK I've decided to go with Block Design Files approach to programming a IV Cyclone in Quartus. Seems easier than Verilog from scratch to me. My application has lots of pins but is fairly simple. ...
8 years agoHi,
--- Quote Start --- For bidirectional I assume I use a symbol ALT_OUTBUF_TRI. Under “Symbol Properties/ports it has 3 names i, o, and oe. It’s unclear to me how I access/connect up to the oe port with wires. The oe does not appear in the schematic --- Quote End --- Check screenshot, You can see the “oe” port. Refer following thread as well for reference, https://www.alteraforum.com/forum/showthread.php?t=38718 Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation)
