10 years agointerface a module with avalon bus
Good evening; i want to know how to interface a module HDL with the avalon bus if any one can answer me Thank you
10 years agoHi Phlibi, I read over your code, it can help understand how to interface avalon Bus but at first glance it has some flaws:
Registers are 32 bit wide- No byte addressing is provided on No status register is provided to check for overflow On avalon write part: if reset = '1' then dac_value <= (others => (others => '0')); elsif rising_edge(clk) then this code reset an undeclared dac_value, I don't see declared on your code post, others is used two times as if op_a was an aggregate so I think about syntax error, IMHO it has to reset op_a and op _b so must look as it follow --- : this version generate an asyncronous reset and probably a latch. if rising_edge(clk) then if reset = '1' then op_a <= (others => '0'); op_b <= (others => '0'); else Process calc is active forever, it is required just when you write one of operand, this save a lot of power. Regards
